It is currently Thu Jul 16, 2026 7:18 pm
PostPosted: Mon Jan 16, 2023 2:50 pm
Hello looking for a couple quick grades please and thank you. Boards are numbered and with back pictures numbered as well.
PostPosted: Mon Jun 01, 2026 5:56 pm
#1 Low Peripheral. Too junky. Think of removing metal.
#2 High Peripheral
#3 High Peripheral
#4 High Peripheral
#5 High Peripheral
#6 High Peripheral
#7 High Peripheral
PostPosted: Mon Jun 01, 2026 6:04 pm
1 is a good case for removing shields (assuming the little ones are also shields), as is or without the metal boxes this looks low peripheral. But if removing them reveals ICs or other goodies then you have a case for moving into a higher grade.
PostPosted: Thu Jul 16, 2026 9:37 am
Wouldn't you want to remove the transformers from 5/6? I normally remove them and toss them in my transformer bucket for my local yards.
PostPosted: Thu Jul 16, 2026 9:56 am
Removing the transformers isn't required and often unnecessary for smaller ones. If a board is borderline it can make a difference though. That being said, 6 I see no reason to remove that one. 5 I think is okay also but I could see removing it if you're unsure.
PostPosted: Thu Jul 16, 2026 11:02 am
Thanks Marked. I guess I have watched too many Shark videos. I believe he always removes the transformers when he goes over grading/sorting boards.
PostPosted: Thu Jul 16, 2026 12:04 pm
It does depend a bit on your specific situation too.
If you have local scrap yards that have great prices for different things, you may want to remove certain items simply for that. In Shark's case he probably does enough volume that having a specific set of rules to follow when processing ensures that every board meets a standard without questioning it and, what I assume is a high volume of transformers, likely allows him to get paid more for the large quantity.
