It is currently Fri Oct 09, 2026 12:15 am
PostPosted: Tue Oct 06, 2026 1:17 pm
As the pictured board is. Not cleaned.
What would it grade as?
Also. If I cut the board at the black line I drew on it. Would it be a good idea?
If you look. You will see a dotted line put on by the manufacturer. Labeling one side hot. The other cold. Basically where I drew my line. Also. Seemily separating a Mid Grade section from a High Peripheral section. If you can see what I mean.
OR! Should I just clean the transformers off. Remove the large capacitor. Also all the small coils.(labeled L). What would it go as then? If it grades as High Peripheral. That's the best choice. In my opinion.
Looking for input. A real e-scrapping question. Especially if one has a large number of boards.
It's complicated.
PostPosted: Wed Oct 07, 2026 9:39 am
Just being funny but it must be nice to be retired and have all that time….
PostPosted: Thu Oct 08, 2026 12:10 pm
the right side of that board is obviously very poorly populated so i don't see why it would hurt it to cut that side off... i agree that i think the left side is worth more by itself in my opinion.
