It is currently Sat Aug 01, 2026 6:22 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Help IDing
PostPosted: Fri Apr 28, 2017 12:42 am
Last ones...for now :-) thanks for the help!
PostPosted: Fri Apr 28, 2017 4:56 pm
@lostinlodos is this just low grade? I'm thrown by the smaller board attachments plus the green with ICs on the back.
PostPosted: Fri Apr 28, 2017 6:56 pm
I'd toss this in low grade (use a box cutter on the edges of them and you can remove the ICs. Worth the few moments effort since this board is low grade.
PostPosted: Sat Apr 29, 2017 5:07 pm
#3 that I posted earlier....the wireless network card..I don't understand "variable (as is peripheral) remove shell and anything from peripheral to cell class inside"
I took it apart. What else do I need to do and what classification is it?
PostPosted: Sat Apr 29, 2017 7:39 pm
Variable in that they don't fit into any single class. With the shell on they go as peripheral every time. Once the shell is off:
They range from peripheral on up to telco. A few will get a special class called air card and every once in a while one can even make cell class.
I need the other side of this for an accurate grade.
PostPosted: Sat Apr 29, 2017 7:44 pm
Here's the back. This little tabs are gold.
PostPosted: Sun Apr 30, 2017 12:13 am
This one's peripheral
PostPosted: Sat May 06, 2017 7:13 pm
What's this Xbox 360 board rated? Anything I should remove?
PostPosted: Sat May 06, 2017 9:15 pm
Peripheral
PostPosted: Sat May 06, 2017 11:22 pm
Anything worth removing? Copper? Processors?
