Bradensboard wrote:
Question is IF I'VE ALREADY TOUCHED THEM
that's difficult to answer. If you removed chips yes you're probably best at this point cutting off the fingers, removing the brackets and most will probably clear peripheral. If you've removed all the chips you're looking at low or midgrade.
Power boards there --low grade. Lens arrays midgrade
The two LED boards (larger brown and green) are low grade.
The small brown vacuum screen is low grade without pins, midgrade if it has silver mini pins on back. The white one is midgrade. Fans are best locally. The big LCD screens... not for board sort but are valuable if not cracked. Google
buy sell Used lcd
Buy sell used screen
The tablet board top right is telco. The one on top of the pile will also probably be telco.
Rest looks good for cell phone board class
Boardsort buys all wire at one rate. Locally you'd probably have to sort that box. Or take high grade shred (15-35¢). Sorted properly you'll get more locally.
Just from the photo you have insulated copper, some silver/tin nickel/tin and #2 in that box.
Unsorted boardsort is better
1) peripheral
2) peripheral
3) midgrade. (Cbm2 locally)
