It is currently Mon Nov 16, 2026 7:58 pm
 Post subject: hard drives
PostPosted: Sat Nov 07, 2026 4:09 am
I recently moved and am downsizing my scrapping. I want to send a few boxes of hard drives. I scrapped the HD boards a few years ago.. When I send a box of hard drives or even hard drive platters is there a certificate of destruction available? I want to know they are actually scrapped.
Let me know !
Love boardsort and the mission these are the long term hold outs!
 Post subject: Re: hard drives
PostPosted: Mon Nov 16, 2026 8:47 am
Let me know !
Not trying to sound negative or nothing..., but if you like, you can send them to me and I'll send ya back whatever certificate you desire for them...
To my understanding, there is not a standard form or process for certifying the destruction of these types of things, it is more of a honor system that it's been done and a paper for the memory i guess... basically anyone can google a template for this and sign it and i wouldn't think you'd have too many options on how to prove it otherwise....
Just saying
PostPosted: Mon Nov 16, 2026 11:57 am
Just saying
Most states have a license platform for secure data destruction. I used to hold one.
You can also do this fairly easily on your own though. (Somewhere in the site is a photo guide i posted on doing it by hand).
Once you remove the platters, use the drive’s own magnet to remove the data. Just place the magnet directly on the platter at the centre and drag it to the edge. And repeat till you have erased the whole drive.
I just use a degaussing plate though. The kind in a permalloy box. Same thing to erase floppy disks and magnetic tape. Standard drives are erased in a single zap. perpendicular recorded and shingled recorded disks are generally need 3 or 4.
PostPosted: Mon Nov 16, 2026 3:30 pm
Why would you not just destroy them yourself if that's what you're looking for?
PostPosted: Mon Nov 16, 2026 4:12 pm
Op is looking to scrap them for hard drive price. Once you ‘destroy’ them it’s not a hard drive rete anymore.
Destroying them isn’t as easy as it sounds; my two methods will get rid of the data.
Simply blowing them up doesn’t destroy the data. Most people don’t have a shredder or that can slice through the platters at all, let alone enough to make data recovery all but impossible.
And contrary to the myth, a bullet does nothing for data protection. Stupid move unless the platters are glass.
PostPosted: Mon Nov 16, 2026 5:37 pm
Someone told me years ago that you can't wipe a drive platter with a magnet. I've always bent the platters. The data still remains on the platter, but it's not easy to recover.
PostPosted: Mon Nov 16, 2026 6:20 pm
That’s both correct and incorrect.
You’re not going to wipe a disk with any normal magnet from most stores. Rare earth magnets will though. The neodymium magnet in your drive however is very powerful. In the 50s range. Data gone aside from clean room recover after a few passes. You can’t get lucky shoving it back in the drive and loading it up.
Generally nobody in their right mind is gonna try to open air recover anyone’s data from bare platters, unless you’re famous, under investigation, or have a stalker/ex/whatever.
Bending them stops anything other than someone willing to spend hundreds to thousands on recovery. Same with a bullet. That said, the data is still there. So if you have a need, or are doing this for someone else by agreement, that’s definitely the wrong way to go.
Best method is easy to do. Which the op can’t easily without the boards.
Grab a wipe app like BCWipe, paid, which I use.
Encrypt the drive first (APFS, Bitlocker etc) through your os
Do. Long format to a different filesystem.
Unmount/eject the drive.
Load up bc wipe and point it to the offline drive.
Do a 4-8 pass wipe unless you are dealing with a specific mandate.
It’s always best to encrypt the drive before you reformat anyway. It takes a bit of time to do so, but the data becomes a mess of cryptic garbage with a translation key. Formatting deletes the key. Wiping kills the key’s recovery along with any data.
For the OP, the best choice to be sure is to grab a boxed degaussing plate. They cost $25-$50 or so. Less online used. And you need to do the individual platters, not the whole drive.
