It is currently Sun Oct 25, 2026 12:42 am
 Post subject: help with these 2 boards
PostPosted: Thu Sep 03, 2026 12:52 pm
need help identifying these 2 boards
PostPosted: Sat Sep 05, 2026 9:38 am
3009.jpg is likely backplane but the picture is awful and I don't know if it's the image quality or the board but it looks damaged, which may impact grade.
7412.jpg picture better than the other, does have some damage (visible rust and broken board) also is pretty dirty (shouldn't impact the actual grade in this case, I'm just less sure what that grade is). My guess the steel brace for the connector isn't coming off without taking the connector with it, so between the steel and the damage I'm leaning low Telco but that's heavily dependent on the actual damage. If the board and components are simply dirty and haven't had any chemical degradation, high Telco and brace should be fine to stay.
PostPosted: Sun Sep 06, 2026 9:06 am
thank you . im new this . and yes they have a layer of dust from being stored in barn for many years . planed on blowing that off with air compressor should have done that before
