It is currently Wed Aug 12, 2026 8:26 am
 Post subject: Multiple Gold Tab BGAs
PostPosted: Sun Aug 09, 2026 7:10 pm
Wanted to float a bit of a moral dilemma by the group and use a recent board as an example. When you have a board like this with 3 gold tab BGA, what do you do? It will likely be peripheral high grade regardless if there are 1 or 3 BGAs, so would I be more of a fool to submit with all 3, or a scumbag to remove 2 and submit the chips separately for an additional payout?
PostPosted: Tue Aug 11, 2026 9:50 am
Depending on how many you have, do the math. Place a value on your time and compare as is with no labor to removing tabs. Its probably not worth the time unless you have a bunch of them. I probably would submit them as is regardless.
PostPosted: Tue Aug 11, 2026 12:14 pm
The moment you depopulate it drops the board grade.
They are quite firm on that.
Just leave them in unless You are going to strip the board completely.
