It is currently Sat Jun 27, 2026 10:54 pm
 Post subject: Hard drive board
PostPosted: Thu Jun 25, 2026 10:41 pm
I have several old hard drive boards that are very densely populated and have gold tab BGAs on them…still just hard drive class? (Asking mostly bc of the gold BGA)
 Post subject: Re: Hard drive board
PostPosted: Fri Jun 26, 2026 2:35 pm
Picture?
sata or non?
PostPosted: Sat Jun 27, 2026 5:48 am
We’ll need a picture to accurately ID.
PostPosted: Sat Jun 27, 2026 3:29 pm
marked141 wrote:
Picture?
sata or non?
PostPosted: Sat Jun 27, 2026 7:48 pm
First and last appear to be non-sata high grade hdd boards
Middle, low grade sata hdd board.
PostPosted: Sat Jun 27, 2026 7:57 pm
So back to my actual question….the Gold Tab BGA doesn’t change anything?
Those are non-SATA but they aren’t SCSI/pinned they are SAS connection…the Boardsort video doesn’t show this type under high or low grade
PostPosted: Sat Jun 27, 2026 9:03 pm
The two non-sata don't have to be a specific type of connection, they just can't be sata to reach high grade hdd. These are typically higher end boards or older boards from when more precious metals were in the components.
The one is sata, so by the grading convention Boardsort uses I can only say low grade hdd. It is a nice board with lots of nice stuff on it, but Boardsort would need to see it if you want to be sure.
PostPosted: Sat Jun 27, 2026 9:05 pm
The bgas don't have bearing on the grade difference. Unless you remove it then it might drop it.
