It is currently Thu Jun 11, 2026 3:09 am
PostPosted: Fri Apr 24, 2026 10:38 am
This one has me stumped. the gold tabbed chip do hicky thingy looks to be gold. what would it go as ?
PostPosted: Fri Apr 24, 2026 11:24 am
Midgrade? Might be an argument for low peripheral.
I'm guessing F1 and the 3A(mp?) means it's a fuse but not sure
PostPosted: Fri Apr 24, 2026 11:44 am
I was thinking fuse too but the gold on the ends is what has me confused.
PostPosted: Fri Apr 24, 2026 8:55 pm
F1 is a fuse. 100% sure. It's just a quality surface mount fuse. Yes. Those are gold plated end caps on the fuse. And yes. It is 3 amp rating.
I don't see me grading the board.
PostPosted: Fri Apr 24, 2026 10:11 pm
sounds like ill be emailing Chriss
PostPosted: Sun Apr 26, 2026 2:15 pm
Nano fuses! Those gold caps are highly gold plated or silver bearing. This is one item I actually collect and refine myself.
If you can gather enough in quantity, BS will buy these at a specific rating. You can also find a jeweler.
These fuses and gold capped in-line resistors, have these style of caps on them. You have to remove the resistors cover/plastic/epoxy or enamel/paint to see the gold caps. (rare though) Mostly on the carbon composition types(fixed resistors).
PostPosted: Sun Apr 26, 2026 2:16 pm
Low Per as is, remove the ferrite CU winding, High Per
PostPosted: Sun Apr 26, 2026 2:23 pm
Always check ceramic boxed or ceramic wire wound resistors too. They do sometimes have heavy gold pins or the actual contact point itself; that's suppose to break connection on overload, is highly gold plated.
PostPosted: Sun Apr 26, 2026 5:14 pm
Spence1015. What are your comments on these two components? I am showing the original condition. And then when I cut them open. Those are ceramic hybrids. I value your opinion.
PostPosted: Fri May 08, 2026 12:47 pm
Sorry for the late reply Cat.
Those are neat. They're considered ICs, dual in-lines actually. I pull similar objects from audio equipment and old visual stuff.
From some kind of sound/audio equipment? or a general DC convertor for something?
If you look very close, you can see the gold tethers to the ceramic dies.
In most Hybrid ceramic units or microelectronic PCBS, they contain hazardous materials inside the substrate; don't break them.
They also usually are packed with goodies like so. Old power supplies contain ceramic hybrids too, I pull em' to put into High Per or Low tel.
