It is currently Thu Apr 16, 2026 9:56 am
PostPosted: Tue Apr 14, 2026 2:35 pm
I have a hand full of bare copper cold plates form water blocks, do they count as clean copper heat sink or would they go as number 2?
EDIT:
here is an example
PostPosted: Tue Apr 14, 2026 2:39 pm
I would think #1 unless there's heavy corrosion or solder on your particular one
PostPosted: Tue Apr 14, 2026 2:55 pm
none of the ones I have have solder or corrosion, got a ton of them from old projects and I tend to melt them to make bronze.
TBH I never seen a cold plate style block with solder. that's more of a cross flow block thing. If I can get #1 for them I might start turning them in. The local yard only gives number 2 for them so I never turned them in.
PostPosted: Tue Apr 14, 2026 4:27 pm
If You really wanted to you could probably find some sort of spec sheet on what kind of copper is used to make them, you could verify that the percentage of copper is high enough for number one.
A scrapyard that’s unfamiliar with that type of heat sink might see the fins and think that it’s not one solid block. ¯\_(ツ)_/¯
PostPosted: Tue Apr 14, 2026 8:34 pm
Name brand ones are clean #1 or copper heatsink.
Lower cost generics tend to be #2 they have up to 5% or so mixed metals like zinc and tin.
PostPosted: Wed Apr 15, 2026 12:39 am
well thats a kicker, no clue what's what anymore. it's all in my melt pile and i've long forgotten what the makers are. guess they'll stay there
PostPosted: Wed Apr 15, 2026 1:26 pm
You’re fine with #2 for the batch. At worst.
PostPosted: Wed Apr 15, 2026 2:46 pm
nope, at #2 I'll keep to make bronze
