It is currently Mon Aug 31, 2026 9:46 pm
 Post subject: Classification?
PostPosted: Wed Mar 25, 2026 7:17 pm
I have about 60 of these boards. Fully transparency, I bought these boards specifically to take off all the gold tabbed BGA's myself so I'm not trying to pull one over on Boardsort. This is just what's left and am wondering what you would classify them as to make it worth your while.  Each of these boards now have a ton of tantalum capacitors, a ton of gold pins (see pic) a lot of IC's and there's a lot of gold printed on the pcb.   I will be taking off all the metal you see.   Each of the boards have 16 smaller pcb's that are screwed in. The first pic is what it looks like without all of pieces screwed in. Each of the 16 smaller pieces also have tant caps and IC's and gold pins.   All in all I have maybe 100lbs of these boards.
 Post subject: Re: Classification?
PostPosted: Wed Mar 25, 2026 9:16 pm
The main board, make sure you remove the steel then it should clear high Telco still but don't remove anymore chips/etc. There's a fair amount of brass there that I don't think you need to remove but it is going to be a less valuable material on the board that could affect the grade. Not often brass gets to be a low value component. xP
The small boards I'd think high peripheral at this point, likely would have been high Telco with two gold tab bga.
PostPosted: Wed Mar 25, 2026 11:05 pm
Thanks for the response! I also emailed Chris so hopefully he’ll agree with that grade. Yeah, the BGA’s on these 60 boards produced 7.5lbs of just the tops (where all the gold is) and I sold them for $3000 yesterday. So, high telco couldn’t have even come close to what I sold them for lol.
PostPosted: Sun Apr 12, 2026 8:09 am
Whew. You sure made a point on depopulating boards. Smart scrapper.
