It is currently Thu Jun 11, 2026 5:27 am
PostPosted: Fri Apr 03, 2026 9:31 am
not 100% sure on all these. looking for second opinions
PostPosted: Fri Apr 03, 2026 9:53 am
Numbers are goofy :P
5. High peripheral
1. Looks like a CD/DVD board but it feels like it's missing some stuff. And not just the little switch that got knocked off
2. Should be high peripheral
3. Leaning low peripheral
4. High peripheral
6. Could be better but at least low peripheral
7. High peripheral
8. I think there's enough there for high peripheral
9. Midgrade
PostPosted: Fri Apr 03, 2026 10:47 am
even with the thick gold pins in the connector?
2 is a odd one, I never pulled a CD board out of a drive with so little on it.
PostPosted: Fri Apr 03, 2026 12:01 pm
¯\_(ツ)_/¯
It could be high, when I'm unsure I tend to aim lower.
PostPosted: Fri Apr 03, 2026 12:05 pm
marked141 wrote:
¯\_(ツ)_/¯
If there was no gold pins I'd say low all day long but IDK with the pins. Its hard to make out in the photo but they're thick and deeply platted, but also very few of them.
PostPosted: Sun Apr 05, 2026 11:46 am
Here is my take on the boards
1. By process of elimination, of the boards is from a CD/ROM from a computee or laptop then it’s CD/ROM board. If I get the board from a CD/DVD player then i put those with my high grade peripheral depending on the IC chips population
2. Low grade peripheral for sure
4. Low grade peripheral. It has only one tiny IC chip
6. High grade peripheral. It has enough IC chips for me to quote it that.
9. Mid grade but it could pass for low grade peripheral due to the gold plating.
PostPosted: Sun Apr 05, 2026 12:28 pm
I based 2 on a previous comment by Lost on a similar board before the peripheral split. It was likely bottom of the grade then.
