It is currently Tue Mar 31, 2026 7:16 pm
PostPosted: Mon Mar 30, 2026 8:35 pm
Attached below are numbered boards. I have higher quantities of these, so they are the higher priority.
PostPosted: Tue Mar 31, 2026 12:18 pm
1. Remove the faceplate, high Telco
2. Is a gold finger card. With bracket or without if you remove it
3. Gold cap chip board. If that's a metal bracket/support on the side, remove it.
4. Not sure how much of the board is cropped out of the picture so not sure on grading.
5. Remove the Dallas box, has a battery in it. Looks like two boards, if the smaller board can be removed, if only so we can see what's on the other side and under it on the big board, please do. The purple ceramic CPU, is it socketed or soldered on? If socketed, pull it to check for a gold cap on the bottom. If soldered, you can carefully drill one or two small holes on the other side of the CPU to see if there's a gold cap.
PostPosted: Tue Mar 31, 2026 1:03 pm
5. Remove the Dallas box, has a battery in it. Looks like two boards, if the smaller board can be removed, if only so we can see what's on the other side and under it on the big board, please do. The purple ceramic CPU, is it socketed or soldered on? If socketed, pull it to check for a gold cap on the bottom. If soldered, you can carefully fill one or two small holes on the other side of the CPU to see if there's a gold cap.
he only needs to remove the cover and battery from the Dallas box, the IC inside it is ok to leave.
4 is likely GFC or telco
