It is currently Fri Sep 11, 2026 1:21 pm
 Post subject: Some GFCS 5-15-2022
PostPosted: Sun May 15, 2022 11:42 pm
Here are a few pictures.
1 & 2) - Should be GFCs w/ bracket. Anything else to be removed?
3) GFC w/ bracket
4) would this go as clean GFC or something else?
5) GFC or something else?
Thanks
 Post subject: Re: Some GFCS 5-15-2022
PostPosted: Wed May 18, 2022 3:24 pm
I think they would all classify as gold finger cards. Take the brackets off if it's worth.10/lb. to you
PostPosted: Wed May 18, 2022 5:08 pm
I feel like #4 may not get to go that route... Hopefully I can look into it better this evening.
Personally I always remove the steel brackets. Remember if you do to check the standoff screws for brass or steel.
PostPosted: Wed May 18, 2022 10:45 pm
Took a bit of searching but I found a comparable board to #4:
viewtopic.php?f=4&t=21029&p=41297&hilit=plasma+board#p41297
So GFC it is.
PostPosted: Wed May 18, 2022 10:48 pm
thanks
