It is currently Fri Sep 11, 2026 10:17 pm
 Post subject: help identifying.
PostPosted: Wed Jun 23, 2021 11:37 am
Location: 1555 Lyell Avenue Suite 120 Rochester, NY 14606
Thanks for your help. I'm unsure about these ones.
 Post subject: Re: help identifying.
PostPosted: Wed Jun 23, 2021 2:50 pm
Most of what I am seeing here (after you pop the screw out and take the clear plastic pieces off) look like they could go in the connector ends pile.
PostPosted: Wed Jun 23, 2021 8:50 pm
Before the low/high peripheral split these would have all gone in peripheral. May need to check ccussins big post that he tried to get us examples of what's low vs. high to see if any of these are in there.
Definitely remove the screw and take the plastic off.
PostPosted: Wed Jun 23, 2021 9:49 pm
Here's ccussins post
viewtopic.php?f=4&t=20857
Based on what I'm seeing 1-3 high peripheral, 4 low peripheral
PostPosted: Thu Jul 08, 2021 10:13 am
Chris says that boards like this go as Low Grade Peripheral since they barely slid into the Peripheral category before. Board 2 will be High Grade Peripheral because of the two chips on it.
