It is currently Sat Sep 12, 2026 2:15 am
 Post subject: Help with board grade
PostPosted: Wed Jun 09, 2021 9:00 am
Please grade my boards
#4 has gold finger not pictured
PostPosted: Wed Jun 09, 2021 9:11 am
1) High Grade Peripheral
2) High Grade Peripheral
3) High Grade Peripheral
4) Clean Gold Finger Card
PostPosted: Wed Jun 09, 2021 4:46 pm
Thank you
PostPosted: Wed Jun 09, 2021 6:03 pm
I have a small issue with your assessment ccussins. 1 & 2 look like CDROM cards. I'm with you on 3 & 4. The reason I have an issue with this is because I tear down alot of CDROMS and alot of my boards are of this type. The pay rate is so different for the two. I don't want to end up getting 2.75 for boards that I should be getting 5.00 for. Thank you.
PostPosted: Wed Jun 09, 2021 8:29 pm
I'll check with Chris then.
PostPosted: Wed Jun 09, 2021 9:54 pm
@malphorian1973, #1 came out of Cisco switch board, #2 is for Cisco router used for two analog lines I should have taken pic showing rj 45 port, will do in future. As much I wish they were cdrom boards they are not.
Ccussins got it correct although #2 remove bracket could go for telco just my thoughts
PostPosted: Wed Jun 09, 2021 10:59 pm
Thank you so much for the clarification. I feel much better now. :) You guys are great!
PostPosted: Sat Jun 26, 2021 11:00 am
Chris says I'm correct.
PostPosted: Sat Jun 26, 2021 5:00 pm
--I obviously didn't read the original post well, which says there are gold fingers that aren't in the picture--
Nevermind :D
