It is currently Mon Oct 12, 2026 7:02 pm
 Post subject: Need ID 2
PostPosted: Thu Nov 05, 2020 10:03 pm
Some mobos to ID.
 Post subject: Re: Need ID 2
PostPosted: Thu Nov 05, 2020 10:40 pm
Metal socket/metal socket
Metal socket/small socket
Metal socket
Metal socket
PostPosted: Fri Nov 06, 2020 1:13 am
Metal socket
Metal socket
It looks like the board in the lower right hand corner of the first picture came out of a laptop. If it actually came out of a laptop, would it be graded as a laptop motherboard?
PostPosted: Fri Nov 06, 2020 3:02 am
Given the other boards my assumption is they’re thin clients. (Inc micro and ultra thin etc.
I get what your seeing completely. But if it /is/ a laptop it’s so low end (no offence to OP if original owner) I just don’t see it.
I’ve pointed out a couple of times before that when it comes to metal socket MBs removing the metal bracket neither changes the grade nor fools anyone.
To further that: the rest of the half LGA mixed sockets will be metal socket. Period.
To the one you question:
Let me take a deep dive into HP. The second largest laptop seller.
The current Z series listed as entry level.
These aren’t laptop boards. Nor is anyone’s Chromebook. The entire premise of a laptop above entry level (basic, midrange, business, gaming, enterprise), is the placing of a desktop computer inside a portable shell.
Low end, being below basic, and chromebooks are just much larger tablet boards. Not downscaling of desktop boards.
The board posted is an mini ITX derivative. Not Atx.
It strips away the majority of individual controllers for a pair of slimmed down ASICs. The PGA socket is an early nm level. Meaning tiny pin sockets. And very few of them.
Chris is a bit more generous than I am and I grade here on HIS low end for these forums. I wouldn’t pay $1/lb for that one personally.
I simply don’t see any way that board would make it as laptop grade even if the the intakes was in Oregon enjoying therapeutic mushrooms with a 6 pack of 4 loco.
PostPosted: Fri Nov 06, 2020 10:31 am
Thanks for the explanation.
Oh, and I noticed the WiFi card is still on that board. If you remove it, it will go as a Clean Gold Finger Card with the shield removed.
PostPosted: Fri Nov 06, 2020 6:03 pm
Yep. Happy little Wireless card.
Good eye.
These look like wyse (dell) or T (HP) based boards. All of those series boards swap between metal socket or peripheral depending on the exact layout.
