It is currently Fri Oct 09, 2026 2:30 pm
 Post subject: Help ID 1
PostPosted: Sun Oct 25, 2020 4:10 pm
Need a little help with these.
 Post subject: Re: Help ID 1
PostPosted: Sun Oct 25, 2020 6:30 pm
1,2, and 5 are mid grade. Depending on how much extruded aluminum is in your area, you could profit a bit more by stripping the heat sinks off #2.
4 has tiny gold fingers, so it could get gold finger card grade. Peripheral if not.
3 is peripheral
6 is low grade. Board must be green on both sides to count as mid grade. Only exception is floppy disk drive boards, which go as peripheral if the connector pins are attached.
PostPosted: Mon Oct 26, 2020 11:46 am
5 should make peripheral. It’s a card reader.
PostPosted: Mon Oct 26, 2020 11:49 am
kgryczan: I’m wavering on 6. Definitely not peripheral but I’ve consistently gotten midgrade for terminal serial boards. They’re nearly identical. Slightly larger.
Thought?
PostPosted: Mon Oct 26, 2020 7:41 pm
Not sure if it makes a difference, but there is a row of gold pins on the brown side of #6.
Sorry the pic is not real clear.
PostPosted: Mon Oct 26, 2020 9:12 pm
See that. The reason I boosted it over low.
