It is currently Fri Sep 18, 2026 8:38 pm
 Post subject: CPU Dummy?
PostPosted: Thu Oct 08, 2020 9:34 am
How should this be classified with our upcoming shipment??
 Post subject: Re: CPU Dummy?
PostPosted: Thu Oct 08, 2020 10:02 am
That’s a Green/Brown no metal CPU currently at $18
PostPosted: Fri Oct 09, 2020 2:38 pm
Not likely. There’s no die.
My immediate thought is pin board.
But I’m leaving this open for a bit to come back to later today after I have a chance to search through my prior sales and see if I can find something Related and what it ultimately went for.
PostPosted: Fri Oct 09, 2020 2:40 pm
148 of the pins are etched to dead ends.
@ diamondcomputer
Can you post the other side?
PostPosted: Fri Oct 09, 2020 4:05 pm
There should be two pics posted, one with pins and the other "pinless".
PostPosted: Fri Oct 09, 2020 11:30 pm
Wanted to be absolutely sure before made a ruling of sorts.
There’s no die here. So generally speaking we’re looking at a high quality pin board.
Best I can place it is as pin board.
There’s a good chance this make make something better when they have it in hand though.
And rather than base this on the single comparable I sent I’ve forwarded this to Chris for an official answer.
As such note for Chris:
Any chance of also telling us what it would be if
A) as is
B) the pins were cut close to the board
And
C) pins punched out cleanly.
PostPosted: Mon Oct 12, 2020 11:07 am
I would agree with Lost on this one, pinboard for sure as is.
I am afraid it would be midgrade after the pins are removed. No real way of determining true value at that point.
PostPosted: Mon Oct 12, 2020 12:09 pm
The two pictures of this are the same item. No pins have been removed that I am aware of. I am guessing my last post "one with pins and the other pinless" should have read "one SIDE with pins and the other SIDE pinless"?
PostPosted: Mon Oct 12, 2020 11:49 pm
We follow that. The question from my end was debating if the pins could be trimmed.
PostPosted: Mon Oct 12, 2020 11:50 pm
Nit logical at midgrade
