It is currently Fri Jun 05, 2026 5:01 am
 Post subject: I'd these 3 please!
PostPosted: Thu Sep 03, 2020 7:31 pm
I'm assuming #3 is midgrade?
 Post subject: Re: I'd these 3 please!
PostPosted: Fri Sep 04, 2020 12:42 am
#3 peripheral
#2 peripheral, remove the little yellow battery ( tab on top, tab on bot holding it in.)
Small flat head works wonders.
#1 Main board peripheral, carefully** remove the metal RF shields.
second, remove the two small blue cards, unscrew the two screws for each and pop/flip cards out like RAM or wifi cards.
Cut wire off but leave gold plated connectors plugged in card. Remove metal shields**carefully, GFC or low/high telco when completed.
PostPosted: Fri Sep 04, 2020 12:49 am
Maybe check the white bulge in the wire too, might be a gold connector end there to cut out or just a ferrite choke.
I always get into the niity griitty iddy bitty, learn more if you don't get more too!
PostPosted: Fri Sep 04, 2020 8:43 am
Thanks guys
PostPosted: Fri Sep 04, 2020 8:40 pm
Remove shields and wires.
Those antenna connectors are gold plate. If plated outside too Send them as gold pins. If just nickel with a gold pin inside they are gold pin connector.
