It is currently Fri Sep 25, 2026 4:19 am
 Post subject: 2nd ic chip id
PostPosted: Sat Aug 15, 2020 7:16 pm
thank you
 Post subject: Re: 2nd ic chip id
PostPosted: Sun Aug 16, 2020 9:55 pm
Flat packs
PostPosted: Sun Aug 16, 2020 10:10 pm
If the chip in the fourth picture has gold pins then it should go green fiber no metal.
PostPosted: Sun Aug 16, 2020 10:17 pm
Yes any chip with pins has a non-gold tab home.
I believe that celeron is bga though, not the pinned kind.
It’s commonly found in ultra portables and non-Linux smart TVs
PostPosted: Sun Aug 16, 2020 10:22 pm
On the other hand if it is the micro PGA type it MAY qualify for green fibre. μPGA is hit or miss on pin length being long enough.
PostPosted: Sun Aug 16, 2020 11:35 pm
I found a similar CPU in a laptop once and it had gold pins. Could a picture of the back be posted?
PostPosted: Mon Aug 17, 2020 12:26 am
I also pulled a CPU exactly like that one out of an old Windows 2000 Dell Latitude laptop. It was a Pentium III and had normal gold pins.
PostPosted: Mon Aug 17, 2020 1:02 am
The pentium III is socket 495. Definitely full pinned.
495 itself exists as both MPGA and μPGA.
This celeron has both pin variants as well as a BGA format used for HP chrome books and Dell ultra portables.
The bga variant is also used for Win-MCE and WIoT TVs. As well as some automotive applications. Bga has a higher vibration tolerance than PGA sockets do.
Mini pins make a CPU rate. μPGA depends on the length. Most do but not all. Stub pins are never a cpu rate.
OP: post the back of the celeron and the VIA
Both have pin and pinless versions.
PostPosted: Mon Aug 17, 2020 1:10 am
For those masochists out there the easy way to tell the difference between stub and μ is to step on it with your heal, pins side up.
μ Causes bleeding. No matter how thick the heal callus is.
Stub pins don’t break through the lower layer of skin.
Some have said stepping on stubs is painful. I find it generally annoying. ;)*
