 Post subject: Id help
PostPosted: Wed Feb 19, 2020 7:39 pm
Are these all gf
And thanks
And on the one with the cable connector do i need to take that metal box off
 Post subject: Re: Id help
PostPosted: Wed Feb 19, 2020 7:41 pm
Oops double pic
PostPosted: Wed Feb 19, 2020 8:40 pm
What are those long boards out of?
PostPosted: Wed Feb 19, 2020 8:51 pm
Looks like the second board came from some HP Proliant server, that is where I see those sorts of cards. But the rest of the boards I have no idea.
PostPosted: Wed Feb 19, 2020 10:59 pm
Edit
1)clean gold finger card
2)clean gold finger card
3)clean gold finger card
4)clean gold finger card
5)clean gold finger card
Oops)low gold finger card
1/2/3/4 much extra board weight
Oops has the heavy analog box and ports.
PostPosted: Wed Feb 19, 2020 11:03 pm
The first 4 are risers from a 2u or 4u rack compatible system
PostPosted: Thu Feb 20, 2020 4:43 pm
lost he would but those all under the clean gold finger rate..
the class grades for gfc seem to have more to do with heatsinks/fans and the bracket then population at the moment ...
Chris Skeeles wrote:
Hello EVILRICK,
Actually I would be comfortable buying those all as the Clean Finger
card with No bracket which is paying $4.25/lb currently.
Chris Skeeles - Boardsort.com Buyer-at-Large - http://BoardSort.com
We buy your scrap computer boards and electronic surplus.
PostPosted: Thu Feb 20, 2020 6:30 pm
Thanks. As always being under is better than being over.
This is going to be a while till we all figure it out. Including Chris.
A few weeks back he graded a processor board riser (very close to the top one) as green small socket so I’m trying to stay in the boundaries of what I can deduce.
I haven’t sent the new classes myself so I’m playing by sight, not practice.
PostPosted: Thu Feb 20, 2020 9:24 pm
Lost,
Are you referring to this board?
PostPosted: Thu Feb 20, 2020 10:21 pm
As to Chris he’ll tell you himself as soon as you have seen it all you find something new.
Yes that: Among others recently.
But there was one I asked on that had fingers.
The top board has a PGA socket, just missing the plastic. Top left. Even well marked as such. Socket 370
So for me, and as such grading, the question becomes at what point does a small riser with small connectors being a motherboard jump to finger card classes. And when to draw the line between too much board (low) and not too much board (standard).
I have a few piles I’m prepping for a shipment of extreme edge cases (sorry for pun). We’ll see how much gets moved around.
Once that’s settled I’ll be more consistent and concise in splitting the new classes.
Such as what to do with low end M2. Low/high telco limit tests. Can a hard disk controller be shrunk so small it becomes high telco despite still having everything for hard disk board?
We’ll find out in the next exciting episode... oh. Oops.
You get the point.
