It is currently Sat Aug 01, 2026 5:51 pm
 Post subject: Other new boards to me
PostPosted: Mon Mar 05, 2018 12:05 pm
A - just GFC?
B - just GFC?
C - Perif?
D - back plane or perif
E - front, nothing on back, Telco?
F - front, pull ICs and stay GFC?
G - front telco?
H - Front, SMD on back, but no flat pack, telco?
I - F & B enough for telco?
PostPosted: Mon Mar 05, 2018 8:51 pm
A)just barely gold finger card. Any less ICs or more other components it would fall to peripheral
B)see a
C)peripheral
D)backplane
E)gold finger card
F)gold finger card (feel free to remove socketed ICs)
G)peripheral. Doesn’t quite make it to motherboard
H)peripheral
I)peripheral
PostPosted: Thu Mar 08, 2018 12:40 pm
I was thinking that 'I', the last two pics was telco because of the full gold flash and all of the big procs(?) on the front and actually having ICs on the back for a change.
PostPosted: Thu Mar 08, 2018 2:30 pm
I think what keeps it from the telco grade is the heavy parts, and expanses of empty board. Just not enough IC density to over come these drawbacks.
PostPosted: Thu Mar 08, 2018 5:50 pm
That’s exactly it. Despite the large controllers, there’s very little ic to board ratio. And fibre CPUs have less value vs ceramics.
The I/o ports are also quite a bit of the overall weight of this board by ratio.
These only have two routes to telco. The first is ceramic Controllers. The second is being slightly older (or much more expensive initially) versions where the boards have a ratio of two channels per controller (2:1). This one has a 4:1 ratio.
Or less technically you need to have a fibre ic for each of the 2-stack I/O ports to be considered for telco.
PostPosted: Thu Mar 08, 2018 7:37 pm
Lost, thanks for the education regarding fiber vs ceramic, good to know!
