It is currently Sat Aug 01, 2026 3:40 pm
 Post subject: Small hard drive
PostPosted: Fri Feb 23, 2018 4:55 pm
First off I'm guessing this is some sort of hard drive. If it in fact is will the board go as hard drive logistics board?
Pictures are front and back.
 Post subject: Re: Small hard drive
PostPosted: Fri Feb 23, 2018 6:35 pm
Follow up to previous pictures and question.
What's the two green boards? Since I now know the blue one is the actual logistics board.
PostPosted: Fri Feb 23, 2018 7:46 pm
The green boards, which are both connected to each other by a cable, are probably peripheral. Make sure to cut the wire connecting the boards and also remove the metal bracket from the smaller board. Also, the hard drive from which you removed the logic board is 500GB, so you could have tested it (if you had the equipment to do so) and sold it.
PostPosted: Fri Feb 23, 2018 8:59 pm
Correct. The blue board is hard drive board class
The others are peripheral. It’s an internal to external adapter
I always caution users about selling drives as working units. Failure rates from shipping are not favourable. Even amazon and Tiger have doa drives and these are brand new.
PostPosted: Fri Feb 23, 2018 9:19 pm
It may be a 500gb hard drive, but its not out of computer or laptop. It's out of a 247 security and tracking system.
I have several more (8 or 10)
I don't have any way or knowledge of how to test hard dives.
PostPosted: Fri Feb 23, 2018 9:26 pm
These pictures is what they came out of and a comparable size.
PostPosted: Fri Feb 23, 2018 11:37 pm
If you can post the ports I can tell you the connectors. The drives themselves are the same as any computer, or laptop in this case.
To test them you’d simply need to attach it to a computer and reformat it, and run a surface scan and SMART diagnostic. I’m guessing SATA or mSATA from the look and size but can’t be sure without seeing the ports head on.
PostPosted: Sat Feb 24, 2018 12:38 pm
We looked at their website and I says a 2.0 USB cable.
PostPosted: Sat Feb 24, 2018 6:17 pm
That is... a usb on the back of the case and what appears to be a serial port as well.
I was referring to the ports on the drive though to tell you how to make them work in a computer.
PostPosted: Sat Feb 24, 2018 9:41 pm
Ohh ok well let's try it again.
On a side note: There is several post about needing idintificacation on soome boards you haven't answered yet. It's highly unusual for you to miss any, it makes me think they aren't showing up on your side for some reason.
