It is currently Sat Aug 01, 2026 1:18 pm
PostPosted: Fri Jul 14, 2017 6:35 pm
I am trying to get my first shipment together and need to know how to classify this boards. Any guidance is appreciated and thank you in advance.
PostPosted: Sat Jul 15, 2017 12:32 am
10)peripheral likely, or backplane depending on the backside
9)peripheral
8)peripheral
7)midgrade
6)telco
5)likely small socket
4)telco
3)telco
2)telco if you can remove the bracing bracket
1)gold cap chip board, and heavy at that. :)
PostPosted: Sat Jul 15, 2017 11:57 pm
lostinlodos,
Thank you so much!
PostPosted: Sun Jul 16, 2017 3:57 am
If 10 has any ports or ICs on the backside it will go as backplane. If not unfortunately it's passive and would go peripheral. I'm guessing it's blank because i see pass through port
9 is missing stuff
7 not sure if this was butchered or just an unfinished piece. Not that it matters for grading. But I recognised it right off and it's missing, well, everything.
5 is a primary controller board. It's missing some of the 'mandatory' things I usually point out but in this case I see it clearing the class regardless.
