It is currently Fri Jul 31, 2026 9:01 pm
 Post subject: Indentification Help
PostPosted: Sat Dec 17, 2016 3:11 am
Have a huntch on what some could be, but just want to be sure
 Post subject: Re: Indentification Help
PostPosted: Sat Dec 17, 2016 4:03 am
Top peripheral bottom midgrade
Peripheral
Same board
Peripheral
Peripheral
Peripheral
Remove shields looks telco or cell class (looks like a go phone; for cell board)
Telco* special case board
Same. Normally stuff like this is perp or below but these are special
There are 3 types of display blocks in units like these, and this is the highest value style.just fold it in half. Separated THiS pair will get telco each
Each screen block has an MC04 unit inside. And I've always gotten telco but make sure you post a picture when you do your quote so they know and review what your sending (not just toss it peripheral by sight). Absolutely worst case it's peripheral for the pad board.
That said Most of these display holding boards will get peripheral; the rather uncommon style with a port and no controller often goes midgrade :'(
Left low right mid.
PostPosted: Sun Dec 18, 2016 10:00 am
And this is Gold I assume
PostPosted: Sun Dec 18, 2016 4:04 pm
Yes the pins are gold. The cpu will be green fibre with or without metal.
If you remove the pins you'll get pinless but the pins here aren't really worth the effort the effort on a bare pin quote.
