PostPosted: Sun Jul 31, 2016 5:50 pm
Hello again,
Hoping maybe someone could advise me as to what these two boards would go as and also if cutting the gold fingers off would downgrade it? (I do certainly understand that in pretty much every case, removing things does downgrade buuuut I figured I'd still make sure!)
Thanks again!
-M
File comment: Possible Telco with very heavy gold fingers
File comment: Motherboard with gold fingers
File comment: both boards in questions
PostPosted: Sun Jul 31, 2016 8:21 pm
Not sure about the fingers on the first one, but it looks telco
Second 2 are metal socket motherboards, and remove the batteries!
PostPosted: Mon Aug 01, 2016 12:10 am
definitely take the fingers off the mother boards.
i think you have enough to clear telecom with out the fingers on the card, but the choice/risk is up to you.
PostPosted: Mon Aug 01, 2016 12:48 am
First one is a radio frequency modulation board (fancy switched modem)
Don't cut the fingers those boards have a tendency to split, crack, and crumble.
And then it falls in price fast!
The metal socket board, feel free to snip the fingers, AFTER you remove the battery. ;)
PostPosted: Tue Aug 02, 2016 4:53 pm
Thank you all VERY much for the help in identifying these guys. For the first one you advised not to cut, what bin should I be placing that in then? I will indeed be cleaning up everything when I have finally finished sorting everything into proper grades so thanks for the reminder on that front as well.
You guys are wonderful <3
PostPosted: Tue Aug 02, 2016 6:04 pm
Telco
