 Post subject: Printer stuff
PostPosted: Sun Jun 26, 2016 6:55 pm
Last 2 pics is that reader that detects the lines so the printer head knows where its at, I forget what it is called.
 Post subject: Re: Printer stuff
PostPosted: Mon Jun 27, 2016 12:56 am
1-9 looks peripheral
Except 7. Boardsort doesn't buy the plastic bracket from the scanner arm.
11 rip the head unit off.
Low grade board
silver /nickel head cbm locally.
10 cut fingers off pop those little gold beads off into a jar l. It's real gold alloy, can send in with loose pins for a quote.Rest is ohkay for mixed wire.
PostPosted: Mon Jun 27, 2016 3:02 pm
7- this is that lightbulb piece with that plastic on it of course. Is there value with this? The so that head on 11, can i put that as a nickel or silver connector or something else
PostPosted: Mon Jun 27, 2016 3:15 pm
Boardsort really isn't set up for them alone. Whole you'll get midgrade for the board. i usually sell them for high grade cbm #1 locally because I'm not dissecting it out. Magnet, pad, nickel etc, cbm1 should get you around 35-45¢ this morning. Better a bit than midgrade.
PostPosted: Mon Jun 27, 2016 3:18 pm
7) you can toss it in steel shred. The ceramic blend has some carbon value and no one has ever said no. Just don't break the tiny florescent tube that was in there somewhere.
PostPosted: Mon Jun 27, 2016 9:48 pm
This seems like a joke, its nearly impossible. Even if I put it in the lightbulb bin at homedepot or wherever, its going to break in there no?
PostPosted: Mon Jun 27, 2016 11:45 pm
Yes but they're set up to deal with the mercury
