PostPosted: Sat May 21, 2016 1:52 pm
I have stripped a bunch of Mac G5s, as well as some G4s.
I would sincerely appreciate if someone could assist in identifying what grades/type of aluminum are shown in the pics I have uploaded.
I also have about 5-10 pounds of Ceramic Monolithic Capacitors (pic taken from your website from another post has also been uploaded for reference). Is there any avenue for selling these?
File comment: Ceramic Monolithic Capacitors removed from asssorted boards
File comment: second pic of heat spreader (or heat sink).
taken at a slightly different angle than the other heat sink pic.
File comment: heat spreader (or heat sink).
Two pics for this one, taken at slightly different angles.
File comment: casings from hard drives
I probably should have left the scrap drives intact instead of breaking them down.
File comment: G5 casing
I have removed everything from the cases that a magnet will stick to.
PostPosted: Sat May 21, 2016 2:23 pm
The moulded heat spreaders are going to be 3260. You'll probably get clean aluminium radiator at a yard.
Hard drives shells, as long as you removed ALL the other materials such as brass pegs and gold connectors and the motor (turn it over and use a number 2 punch and hammer.). You may need to still pry the copper ring if the motor splits. will go as clean spun aluminium
The case for most G4 and G5 towers are manganese or manganese /al alloy. If alloy, goes the same rate as al car rims.
CMC/MCCs you'll need to track down a specific buyer. Google is your friend. Also try asking local jewelry and coin shops that buy gold. Some may be interested.
PostPosted: Sun May 22, 2016 4:12 pm
scratch the base of that heatsink with a file...sometimes they are copper with a silver colored coating
PostPosted: Sun May 22, 2016 4:53 pm
Good call, though i haven't found copper radiators in G series it's worth looking anyway.
PostPosted: Thu May 26, 2016 11:58 am
Thanks to all that provided replies.
Trevor J.
PostPosted: Thu May 26, 2016 12:20 pm
Just a quick follow up. He's got a fair point on spreaders.
The 'genius' guide (for store employees and authorized repair) states that its 3260 specifically but any after market spreader In an apple will probably be copper with a nickel plating. alot of early Intel macs had a nearly identical copper unit available 3rd party to help cooling monster heat of core chips in the mang shells.
(The got well over 90° and I've heard of chips frying at 150°+؛ ouch!)
