 Post subject: Need a little help
PostPosted: Sun Apr 10, 2016 1:01 pm
Thanks
File comment: Back
File comment: Front
File comment: Battery?
File comment: Is that gold plated? Iknow I seen a forum on here on how to take this apart and what to remove out of it.
 Post subject: Re: Need a little help
PostPosted: Sun Apr 10, 2016 5:18 pm
The three dlp boards will all go peripheral
Yes that's a battery
There's a breakdown in my what's inside it threads there's a tiny dlp that will ge either as green fibre with metal or green fibre dlp. A bit of copper. Some random bits and pieces of stuff.
Honestly at this point in scrap prices i cut the laser assembly loose. Pop out the dlp. throw the laser array in cbm#1 the bars in 300 or 400 steel depending on magnetic pull and the outside bracket mount in lt iron.
see here for the catalogue to find the volume and page for dvd/cd assemblies.
PostPosted: Mon Apr 11, 2016 1:37 pm
Will read threw and brake them down. Is that little drive on that pic is that gold plated ?
Question? On a previous dlp board look a little different then these you posted a response that it was a green fiber with metal what is the difference or how can you tell the difference?
PostPosted: Mon Apr 11, 2016 2:07 pm
It depends on size/design.
And the band of 'gold' is probably brass.
PostPosted: Mon Apr 11, 2016 9:54 pm
I see thank goodness for boardsort because some of these boards are confusing to figure out ....
I also sent you an e-mail
