PostPosted: Wed Dec 10, 2025 7:16 pm
What am I looking at here. Have not come across these before
PostPosted: Wed Dec 10, 2025 10:07 pm
Hmm...
Initial reaction is some kind of battery but I have no idea. Would be curious to see a couple other angles of it if you are up for adding more photos.
PostPosted: Wed Dec 10, 2025 10:37 pm
Will get more pics in the morning.
PostPosted: Thu Dec 11, 2025 5:12 am
Reminds me of a typical nickel cadmium battery stack. Probably is. The corrosion on the left terminal is typical of that type of battery. Should be a B indication near it on the PCB itself. It is 3 nicads cells welded in series to get approximately 3.6 volts. Enough voltage to maintain memory circuits for the PCB when powered down or even removed from the device it is in. If it has some silver plate on it. I wouldn't be surprised. Dispose of properly. Or recycle.
PostPosted: Thu Dec 11, 2025 7:57 am
B501 on the pcb as suspected
PostPosted: Thu Dec 11, 2025 7:58 am
More pics
PostPosted: Thu Dec 11, 2025 7:59 am
Last one
PostPosted: Thu Dec 11, 2025 10:30 am
Varta is a battery manufacturer. Based on the pics and the whiskered ones input plus that B on the board itself, battery!
PostPosted: Thu Dec 11, 2025 1:31 pm
If those are Nickel/Cadmium, make sure to dispose properly at your local land fill or recycling center
PostPosted: Thu Dec 11, 2025 6:24 pm
Thank you guys
