 Post subject: Few more ID needed
PostPosted: Mon Oct 20, 2025 4:12 pm
Can I remove the gold fingers of bottom board without degrading the board ?
Thanks
File comment: Back
File comment: Front
 Post subject: Re: Few more ID needed
PostPosted: Tue Oct 21, 2025 1:49 pm
The board with the fingers should go at least low if not high telecom as is after the battery is removed. Don’t trim. High peripheral if trimmed.
The board to the left of the one with fingers and the board in the middle of the top row should also be able to go in low telecom.
Rest high peripheral.
Remove steel from the back of the second board from the right, it is under the long yellow barcode sticker.
PostPosted: Thu Oct 23, 2025 12:21 pm
Bottom row second from left is an apple cpu
