PostPosted: Tue Apr 01, 2014 7:36 pm
I have had this sitting for forever what should I do with it. It has to way over a hundred pounds.
PostPosted: Wed Apr 02, 2014 7:08 am
I don't want to sound rude, but almost every question you ask can be answered by looking at the "E-scrap Gallery", or other sections of this site.
The short answer is take it apart.
PostPosted: Wed Apr 02, 2014 12:57 pm
Alright no problem my bad didn't know their were rules to posting here. I won't anymore just was looking and asking so I could get the most out of it didn't mean to damper your day and post what I have.
PostPosted: Wed Apr 02, 2014 1:17 pm
Judging from what I see in the photo, the cards in the middle are easily removed. Post photos of them here and boardsort will tell you what grade they are. The chassis appears to be steel. Test with a magnet to find out if it's non-magnetic stainless or not. The power supplies can be removed and if you desire, strip them of any transformers or heatsinks inside. Depending on age of the system, you may find gold cap chips in there. I've seen some nortel boards use gold cap chips and others use black fiber intel chips. If there's a hard drive inside, wipe it with a disk wiping utility and then scrap it for the controller board and metal. Anything else you are unsure of, photograph it and post it here.
PostPosted: Thu Apr 03, 2014 5:13 pm
PostPosted: Thu Apr 03, 2014 7:48 pm
I'm not the expert but they would be in my telecom pile
PostPosted: Fri Apr 04, 2014 9:39 am
OK I found this board in it and it has 6 of those little chips on the board to pull out. I figured also it was high grade telecoms just wasn't sure.
PostPosted: Fri Apr 04, 2014 10:40 am
It appears to be telecom grade. Can you snap a more close up photo of the one board that you show on the left in your first photo posted here along with clearer photos of the other boards. I had a hard time figuring out what was on the boards due to lighting and camera shake.
PostPosted: Mon Apr 14, 2014 4:21 pm
Just as kgryczan correctly stated, IMG_20140403_161154.jpg are telecom boards. As far as the others, I cannot see them well enough to know.
PostPosted: Sun Jun 01, 2014 7:15 pm
High Grade Telecom or low grade?
