PostPosted: Mon Jul 17, 2023 4:04 pm
Theese are just some of the strange things I've come across since I started collecting all the escrap I can find I have quite a large stock pile alot I still need to process but I live in ohio so I plan to drive it all in rather then ship it but I am trying to have it all separated to the best of my ability so if anyone knows what theese would be or if they have a value somewhere other then just escrap any info would be greatly appreciated
PostPosted: Thu Jul 20, 2023 7:24 pm
You will need to dismantle it. The connectors are connector ends, and the rest is shred or sheet steel or low grade iron or whatever your scrapyard calls it.
PostPosted: Sun Aug 20, 2023 11:46 pm
thankyou do you have recomendations on how exactly to remove the white rubber plastic stuff? ive tried to dismantle a few other ones similar to this with a similar filling like material and i can never quite get it all off ? thanks
PostPosted: Wed Aug 23, 2023 1:33 am
These are can bus remote I/O modules. The rubbery stuff is know as potting material and is not easily removed. often the casing on these are stainless. If the connector ends will spin and break off that is likely you most value. The P/C board inside has a small micro controller and some I/O chips, and copper traces,none of which have much value. I am fairly sure there is not enough of anything of value to justify tearing these down. After removing the connector ends it would go as dirty stainless at my scrap yard.
PostPosted: Wed Sep 06, 2023 2:40 am
thankyou for the info that response was more like what i was looking for
