PostPosted: Thu May 04, 2023 9:54 pm
Hello. Need help with grading for shipment. Pictures are front and back. Believe number 3 is from a apple cpu. No idea on number 4. Thanks in advance.
PostPosted: Mon May 08, 2023 10:06 am
# 1 and 2 would go as 386/486 CPU because of the gold cap on the bottom. #3 I 've never seen an Apple CPU like that, they usually have other flatpacks on them. https://boardsort.com/images/codes/3001.jpg
#4 looks like Peripheral Low Grade unless you trim the LEDs off the end, then it should be able to go as Peripheral High Grade.
PostPosted: Tue May 09, 2023 9:45 am
Thank you ropeman for your help.
PostPosted: Mon May 15, 2023 9:12 am
#2 might be an engineer's sample and could be worth well more than scrap price. I would research the hell out of that one! Good luck.
PostPosted: Tue May 16, 2023 4:08 pm
Thanks malphorian1973, I'll do some research.
