It depends on the board in question and whether boardsort is able to readily identify that two pieces of board are actually one board.
For instance:
if you break a stick of desktop RAM in half without losing any chips you're probably not facing a downgrade, or
if you break a motherboard in half and the two halves aren't keep together, you're definitely facing a downgrade, dependent on exactly what components ended up on each half but if you keep the pieces together so boardsort can see both halves are there then.
_________________ Here to learn more so I can recycle more My grades are my own opinion and not an official grade from Boardsort
