 Post subject: gold pins
PostPosted: Sun Feb 02, 2020 10:35 pm
IMG_0450 & IMG_0451 are front and back.....can I pull the pins without downgrading the board?
IMG_0452......any suggestions on how to get the plastic off of these pins for "clean gold pins"
 Post subject: Re: gold pins
PostPosted: Mon Feb 03, 2020 2:33 am
Two pictures below — Boards are midgrade without the pins
Pins attached to boards use wire snips. Snip the plastic between the pins. Then Use a nail cutter to remove the pins from the board.
I wouldn’t (and don’t) worry about the tiny bits of leftover plastic after that. Chris is going to downgrade you a few cents a pound; if at all.
PostPosted: Mon Feb 03, 2020 11:09 pm
I want to cut those pins, but that ^ Umm maybe not....lol
