So I have an array of boards from various places that have been ripped apart over the last year. It'll cost me about 50 cents a pound to ship these in, so economically makes no sense to deal with anything here that isn't peripheral or better it seems.
For that, the board is going to need to be green on both sides at the least, yes?
Any brown board such as comes out of a power supply, CRT monitor, VCR, etc would be low grade, yes? I dump it off for a couple pennies at the local yard.
I've removed the batteries I know about in all the attached pictures, but browsing through the forums I see comments about batteries in pictures that I don't even see. If you spot one let me know.
I've attached pictures for any further questions:
| Attachments: |
File comment: Those bottom pieces from flat screen monitors?
File comment: That card in the lower left gold fingered?
File comment: Those 2 boards stacked in the lower right?
File comment: Upper 3 pieces on the right?
File comment: Piece on lower left and upper right? The others being junk?
File comment: Gold finger card on the right, anything useful with the other two?
File comment: Smaller cards from that phone system. Is it the size or connection points that will push it to peripheral or something with the density of parts?
File comment: Front and backs of these. Bunch of controller boards out the phones of the phone system I ripped apart.
File comment: These from a phone system switch. Would they go as gold finger cards? Again with the ball I would normally think to pull off?
File comment: That's a gold finger card at the top? And on the bottom, assuming it were enough to warrant going here, I would normally think to pull off something like that circled?
File comment: An old AT board. I've removed that battery circled on the left, and I've been told I should remove all the chips like circled upper right?
File comment: Remove these pink circled heat sinks? Similarly would I remove heat sinks from video cards?
