It is currently Sat Jun 15, 2024 8:11 pm
 Post subject: Odd items
PostPosted: Wed Feb 07, 2018 10:48 pm
These are out of mobile video equipment.
File comment: The base is ceramic, I tried to pry the board up it appears to be gold backed.
File comment: Any value in this?
File comment: What's the chances of the ends being gold plated?
 Post subject: Re: Odd items
PostPosted: Wed Feb 07, 2018 11:26 pm
Midgrade
Peripheral
Not really
Very high
PostPosted: Thu Feb 08, 2018 4:36 am
Does Boardsort take the "supercool" pack?
Do I need to pull the jcomco board off of the ceramic base?
Is the ends of the wire gold pin connectors or should I send them in separate?
PostPosted: Thu Feb 08, 2018 5:40 pm
Supercool is usually found on midgrade boards. If you send it in that’s where I’d put it myself but honestly a large local yard is a better choice. Beryllium, boron, copper, manganese, and carbon on those. Most recyclers who take the two Bs will take those as CBM
Nope, just remove the shield
The nuts and bolts I’d throw in gold pins. The end connectors I’d bag separate. What they do with them depends on many factors including thickness of gold and the Substrate metal.
I see a lot of that on A/V equipment and that’s what I’ve always done with it.
