PostPosted: Fri May 12, 2017 10:50 am
So I have a lot of old flash memory, specifically Compact Flash. Most are 512MB or 1GB, so not too desirable as memory anymore.
I opened one to see what the board looked like.
With the plastic and metal casing they weigh a little over .2 oz, stripped down to this point there is almost .1 oz.
Is there enough here to send in? Stripped I could see this being comparable to RAM
What would you rate it as without breaking them down?
File comment: Compact Flash memory
PostPosted: Fri May 12, 2017 3:54 pm
These will usually go as peripheral. When they're fully loaded you can edge into telco but pictured will be peripheral
