PostPosted: Thu May 22, 2014 5:32 pm
I believe they are just ceramic chips not sure if amd or pentium category
PostPosted: Fri May 23, 2014 1:57 pm
Unfortunately that top weighs as much if not more than the chip does. We buy those as P4 (you can see it in our material database). But if you can manage to pop the top off (without damaging the chip) we can purchase it as an AMD ceramic.
PostPosted: Sat May 24, 2014 8:41 am
Will removing the metal off of any CPU upgrade it? I've never tried, worried I would damage it. Also, is there an easy way to remove the metal?
PostPosted: Fri Jun 06, 2014 1:29 pm
If you manage to get the top off without damage it would pay the same as an AMD Ceramic but good luck with that, those caps are tight.
