 Post subject: Lots of misc to grade.
PostPosted: Mon May 12, 2014 7:58 pm
Hello,
First time posting pics so if you have suggestions on quality, size, etc im all ears. Need help sorting these components and grading them.
File comment: USB/ audio board in front of pc tower.
File comment: A few more USB/ audio cards. Lots of gold pins.
File comment: Right 2 are media card readers from the front of the tower. The middle top board is from a keyboard (note the little gold circles)
File comment: Some backplane cards i assume, one with gold fingers and one without. Also a vga board, not much there.
File comment: Don't know at all what these are. I think they are the same board just from different companies.
File comment: Brown cards with audio and usb, didn't know if they were worth less than the green board variety. Also, is the bottom left board worth anything much as is or would i be better off tearing off the gold pin connector and tossing the board?
File comment: 2 USB connectors. Do I need to tear them out of the plastic for them to be gold connector ends?
PostPosted: Tue May 13, 2014 7:56 pm
the boards from sets 1-3 are peripheral grade.
set 4 - top item is a backplane. bottom left is a fingered card, bottom right is peripheral.
set 5 appears to be hard drive boards.
set 6 would be peripheral grade.
the last item you can toss with your cable ends.
PostPosted: Thu May 15, 2014 9:31 pm
Very good assessment kgryczan ... very helpful for those odd cards! Thanks! Just a note, I thought all boards with brown/green sides were low grade? See Picture 6. I would've tossed them.
PostPosted: Fri May 16, 2014 6:58 am
I believe the come frome floppy drives but since they have gold pins is the reason for the periphial grade that is my un
derstanding
PostPosted: Fri May 16, 2014 11:26 am
I did some image searching online and kgryczan was right about the hard drive boards. They are LAPTOP HARD DRIVE logic boards, much smaller than desktop hard drive boards but i'm assuming still worth as much.
PostPosted: Fri May 16, 2014 11:30 am
Just thinking, the big audio board in picture 2 has gold fingers, not to mention alot of gold pins for jumpers and connectors besides. Would it be considered a gold finger card?
