It is currently Fri Jun 05, 2026 8:16 pm
PostPosted: Sun Dec 18, 2022 4:21 pm
Please help Identify & Grade Thank You !! D.E.F. !
PostPosted: Fri Jun 05, 2026 10:10 am
All High Peripheral.
PostPosted: Fri Jun 05, 2026 10:28 am
not so sure with E and F, I think e came form a floppy drive, a 5 1/4" one so it could go as CD drive but with the gold edge and all the chops, the gold pins I feel like it could be a telco board. F IDK, looks a lot like a motherboard, it has a agp slot, PCIX? and a cpu socket, is that a apple g4 motherboard ??? would those go as a large socket board ?
PostPosted: Fri Jun 05, 2026 11:30 am
It is an apple mobo. Says apple 2002 in the top right.
PostPosted: Fri Jun 05, 2026 11:50 am
Lost has graded 5.25" floppies from clean gfc to Telco in the past.
viewtopic.php?f=4&t=3135&p=10165&hilit=Floppy#p10165
viewtopic.php?f=4&t=1322&p=4471&hilit=Floppy#p4471
PostPosted: Fri Jun 05, 2026 12:00 pm
*puts on on man glasses* well ill be you're right!!
PostPosted: Fri Jun 05, 2026 12:03 pm
marked141 wrote:
Floppy drives boards can be real toss up, some are mid grade, some are telco, some looks to be peripheral. I sent more then a few 3 1/2 drive boards as CD drive boards too. I think we need to take floppy boards on a case by case biases.
PostPosted: Fri Jun 05, 2026 12:16 pm
3.5" are fairly standard. All gold pins still present, high peripheral. Otherwise midgrade
5.25" will likely vary more but intact should grade fairly well compared to smaller drives.
PostPosted: Fri Jun 05, 2026 2:29 pm
Not really all that standard, some have only 1 or 2 tinny ICs and the rest is junk. Others are covered in ICs and you can find ones in between too. I pulled one away back that no ICs on it at all. But the better populated ones with gold pins can be sent in as CD boards all day long, I been sending them as CD since I started selling to board sort and never once had a down grade.
PostPosted: Fri Jun 05, 2026 5:18 pm
This is the only mention I can find of things outside CD/DVD, going as such viewtopic.php?f=11&t=22775 :
lostinlodos wrote:
CD Boards include a few outside things. Clearly cd, dvd, bluray.
Also most tape drive boards. Super floppy type (dozens or hundreds of megs).
Every post I've gone back through says those 3.5" floppy boards go (high) peripheral, almost entirely due to the pins being on them.
So maybe you're referring to super floppy? In which case I would love pictures so I can learn.
On the board here though you said it's 5.25" and based on what I found searching, CD/DVD is grading that too low.
