It is currently Sun Oct 11, 2026 8:31 pm
PostPosted: Sun Oct 11, 2026 12:29 pm
This is a first…what the heck do I do with this?
Attached to a large with gold fingers. But. Lithium??
PostPosted: Sun Oct 11, 2026 1:44 pm
These suck.
If I can do so safely, I try to clip them one end at a time carefully with a mini bolt and nut cutter
If not, I desolder them.
PostPosted: Sun Oct 11, 2026 1:47 pm
Maybe I’ll just cut that chunk of board out
PostPosted: Sun Oct 11, 2026 2:56 pm
I had a small mountain of gps tracking collars that each had a soldered lithium battery. Clipped one end at a time like lostinlodos said and then put them in rows on tape. Wrapped each row up made a brick and then wrapped it in plastic and took it to my Battery drop off.
PostPosted: Sun Oct 11, 2026 3:14 pm
Also always carefully crack open that type of dip switch, the red one.
You may have silver or gold springs (melt value), or gold plated balls (clean gold pins), or even gold balls.
