backplane mounted on aluminum side runners. Each slot has machine screw holding it to frame and board. Nothing on back of boards except solder over pinholes. With Aluminum removed, weight is still 4 pounds or better. At backplane rates, that should be a ten dollar board. Now for the three heavy gold pin connectors in the maroon plastic. Should they be removed and pins pulled for gold pin rate. Maroon Connectors also have screws into board. Board size 12 inches x 24 inches (rough measurements)
